[BUG] [Working] Unable to handle apostrophe in device name
peepsnet
I was just made aware that the routers firmware cannot handle an apostrophe in a device name.
See Here and here
I have traced it to a function call "get_folder_tree()" in /www/aidisk/getfolderarray.asp:
where this is returned:
var result = [<% get_folder_tree(); %>];
var result = ['WD easystore 25FB#0#1', 'SanDisk' Cruzer Fit#1#2'];
Is there a way to update the code in the function: get_folder_tree()
I searched all the files under /www but could not find the file containing the function.
admn@router:/tmp/home/root# grep -rn '/www/' -e 'get_folder_tree'
/www/aidisk/getfolderarray.asp:10:var result = [<% get_folder_tree(); %>];
/www/aidisk/getfolderarray.asp:13:function get_folder_tree_success(){
/www/aidisk/getfolderarray.asp:18:<body onload="get_folder_tree_success();">
/www/getfoldertree.asp:1:<% get_folder_tree(); %>
/www/gettree.asp:1:treeitems = [<% get_folder_tree(); %>];
Is it part of the web server??
What can we do??
If it can't handle it then simply just don't use it. Why bother. :rolleyes:
Because I don't have another USB that doesn't have a '
I can buy one or just fix it for everybody
That's ActiveScript, meaning that's not a Javascript function, it's processed at run time by the web server.
So would that be up to Asus to work on or is the Webserver something we can touch??
and that variable is stored in a client-side script that appears to be javascript but the www files are R/O
Should be fixable, these portions of the code are usually open.
It's not a variable, it's a tag that gets processed by the web server before being pushed to the clients. Very similar to how PHP works, for example.
What router and firmware version are you using? I just checked the code, and it's using double quotes for elements, not single quotes.
I was just given a FW to test and it is working. I am waiting for final thoughts and testing
RT-AC3100 384.16_beta2 at the time of OP
Two places in httpd/web.c need to be changed from single quotes to escaped double quotes.....search for the string
"'%s#%u#%u'"
Let me know if you want me to send you the patch....
"'%s#%u#%u'"
I only checked the function mentioned in the first post, I didn't check for other functions being possibly broken.
I'll fix the two other cases, thanks.
