Bugs
outlaw78
Not sure if these bugs I list are fixed in the betas or not, but I use 384.3 stable release and when I go to delete the list under Two way IPs, they don't delete and then I have to reboot the router to get the WebGUI to work again. However you can delete the number of hits without a problem.
Also, when you enter data in the "Port Trigger" section, you can not delete them as well.
R Is EMF IGMP broken on AX-GT6000 or L2/CAM table bugs exist ? Asuswrt-Merlin 2
