Building a Homelab
robMad
Hi - I was trying to find the best place to post this, and happy to contribute back the deployment walkthrough when it is all working. Given my existing network gear, I elected for this forum
I want to take my existing home network - designed to be wife friendly and update it to include a Home Lab and a Work Lab. My son lives away from home, but I want to put a few machines in the Home Lab (to do media streaming etc.) and create a work vlan
I already have a GT-AX11000 router and GT-AXE11000 router, and Netgear JGS524Ev2 24-Port and GS108Ev3 8 port managed switch. I would prefer not to start again on the hardware, but happy to look if prices are not too crazy.
My current thinking is as follows:
                Internet
                pfSense
 Home Network   Home Lab      Work Lab
  (VLAN 10)      (VLAN 20)     (VLAN 30)
 PCs, IoT         NAS,        Test Services
 Devices, TV     Media Server
Reading some of the articles, I am contemplating putting the ASUS kit on the Home Network only. I have been looking at some small boxes, such as the Protectli Vault FW4B, and possibly just park the ASUS in the Home network.
I am open to any thoughts on the network and pointers on tutorials if others have done something similar.
Well, the best option would be to have one router/firewall (pfSense) to take care of all the traffic and the VLANs connected to a managed switch. Now the GS is managed but only has 8 ports. Is that enough for your purposes? Not much you can do with the JGS switch as it is unmanaged and you do need a managed switch for VLAN's. Also, i can't think of another purpose than to demote both GT routers to access points and use the ports as an extension of the GS-switch.
Honestly, you would be better off selling both GT routers and the unmanaged switch and get a bigger managed switch and a couple of decent access points. With those, you could deploy the VLANs all the way to unique SSID's for each VLAN. You could use the smaller GS-switch for local LAN port expansion.
                Internet
                pfSense
My guess is your wireless would not work well. If you turned off wireless on the wireless routers and used 2 APs it might work.
I think you would be better off building a real network business class. Wireless routers are too limited when it comes to building real networks with lots of networks in them.
KCL 2nd Office in Same Building -- Best Practice? Other LAN and WAN 2
