Can ExpertWiFi routers be used with non-ExpertWiFi routers in a mesh/AP scenario?
maxbraketorque
Not sure where to put this question - As the title says, can ExpertWiFi routers be used with non-ExpertWiFi routers in a mesh/AP scenario, specifically, do I get the same level of integration as using two non-ExpertWiFi routers in a main/mesh or main/AP scenario? This would be for a non-ExpertWiFi router running 3006.
I have some experience with this setup per my signature. Currently testing SDN VLAN capability with EBG15 as primary Access Point with AiMesh.
You get a single primary network/SSID which surprisingly works with WPA2/WPA3-Personal, (meaning 6 GHz bands, of which I have 2), get properly set to WPA3-Personal. There's a lot more SDN/Guest Network Pro profiles while in Router mode (EBG15), but it is underpowered with USB HDD (4 TB) connected that I switched it to AP, which leaves 4 to choose from...
