Can I use a DSL-AC68U as wifi extender with RT-AC68U
fryster
Hi all, based in the UK and have been using an Asus RT-AC68U router with virgin media for a long time now. Looking to make use of aimesh and extend the range to the bottom of my garden. I've seen a very good deal on a DSL-AC68U, would this work as an extender to achieve what I need? The price is too good to turn my nose up at, so hoping this will work! I'm currently on stock firmware, but have used merlin software in the past. Many thanks!
I use my old DSL-AC68U as an AImesh node to extend a ZenWifi CT8 2 nodes setup. It works well with the ASUS firmware.
Definitely going to give it a go, worse case scenario will be selling on the router at a profit anyway!
I haven't had much luck with using mine as an AImesh node, but that could be due to mixing it with an AX router, so it could work well for you. I couldn't seem to get wired backhaul working on gnuton's Merlin fork, not sure if it's any different on official.
In the end I just gave it a different IP to my main router and disabled stuff like firewall, DHCP server etc and it's working well that way as a wired AP. (it doesn't have the option to just set it up as an AP like other routers do)
I am in the US and was on the phone with Asus support a few days ago. I had some problems using my RT-AC68U with the CenturyLink Actiontec modem/router in bridge mode. I asked about a replacement for the Actiontec and the DSL-AC68U was the reply. I was assured that they would work together in mesh.
