Can No Longer Edit Dual Wan Table 384.3 on RT-AC68
bikermiker
Moderator:
If there is a proper place for bug reports please move this post and show me where I need to go. I looked I promise.
Since updating to 384.3 I can no longer erase entries in my dual wan routing table. I can add them. I can't overwrite them either.
Moderator:
Did you try using another browser? Maybe it's only a browser specific glitch.
Try with 384.4 beta - it's working correctly for me with that version.
No luck. Issue with 384.4 fresh install today on the RTAC56U: cannot edit the WAN Unit entry (no more dropbox). Delete works.
I reset the RTAC56U to factory after loading the new firmware, with 5 sec press on the reset key.
Tried from Chrome and Edge browsers.
I hope we will get back the ability to change the primary/secondary routing without having to delete and add.
Open your browser console and look for any Javascript error. As I said, it's working fine for me, so something in your configuration is preventing the Javascript code from working correctly.
What is a browser console? Is it on the Asus or in Chrome?
