Seth Harman
I currently have an AC86U as my main router and an AC3100 operating as an AIMesh node with ethernet backhaul. The guest network is currently running and I use it to isolate my IoT devices. The one device I cannot add to the guest network via WiFi is the Hue hub as it requires an Ethernet connection. Is it possible to add non-WiFi clients to the Guest Network by giving them a fixed IP and then telling the router to include that IP address in the Guest Network? If not, is it possible to assign one of the LAN ports on the AC86U and tell the router to add anything connected on that port to the Guest Network?
