IPv6 GUAs for Isolated Guest Network?
These scripts work on 3004.388.9, minor changes might be needed for 3006.102 & your vlan bridge config.
"/jffs/scripts/firewall-start"
#!/bin/sh
#Allow all Guest Networks IPv6 WAN access
#Use "ip6tables -vnL FORWARD --line |grep eth " to get line number, change FORWARD # to insert after that line
ip6tables -I FORWARD 12 -i br+ -o $1 -j ACCEPT
3004.388 "/jffs/scripts/dnsmasq.conf.add" use same file for multiple bridges
3006.102 "/jffs/scripts/dnsmasq-1.conf.add" use new file(dnsmasq-index#.conf.add) for multiple bridges?
# Guest Network br1 IPv6
# DHCPv6 RA interval: 10s, router lifetime: 600s
ra-param=br1,10,600
# DHCPv6 range: whole subnet, constructing from br1's prefix
# DHCPv6 prefix length: 64, mode: Stateless DHCPv6
# DHCPv6 lease time: 600s (10 minutes)
dhcp-range=br1,::,constructor:br1,ra-stateless,64,600
"/jffs/scripts/dhcpc-event"
#!/bin/sh
setup() {
# Get IPv6 Prefix for BR0
PREFIX=$(nvram get ipv6_prefix)
BR0_NET_ID=$(echo $PREFIX | cut -d':' -f4)
#Set IPv6 Prefix for BR1 - "0x1" is subnet id in hex
BR1_NET_ID=$(printf "%x" $((0x$BR0_NET_ID + 0x1)))
BR1_PREFIX="$(echo $PREFIX | cut -d':' -f1-3):${BR1_NET_ID}::"
ifconfig br1 down
logger "br1:Down"
ip -6 addr add "${BR1_PREFIX}1/64" dev br1
logger "br1: Setting IPv6 address"
ifconfig br1 up
logger "br1:UP"
teardown() {
ip -6 route flush dev br1
ip -6 add flush dev br1
case "$1" in
bound)
teardown
setup
started|informed|updated|rebound|ra-updated)
setup
stopped|unbound)
teardown
esac
