Cannot access RTorrent
NeoXx
I usually access RTorrent via http://192.168.50.1:81/rutorrent/ where the IP address is the address of my router. However it suddenly stopped working and I deleted RTorrent and reinstalled via opkg install rtorrent-easy-install.
Port left as default at 81, however I still cannot access it. I just receive a message: 'ERR_CONNECTION_REFUSED', This site can’t be reached. 192.168.50.1 refused to connect.
Tried with multiple devices, and checked that lighttpd and rtorrent are running.
Any help is appreciated.
I can see this when I try to open rtorrent in ssh:
Could not read resource file: ~/.rtorrent.rc.
Any advice?
Do a fresh install of rtorrent/rutorrent.
This did not work for me.
I just did a clean install of Asus Merlin on my new RT-AX86U. Have the same issue as op.
If I use that rc.func lighttpd fails to start.
With the default one it starts but I still get that web error.
I expected this to be common and find a solution here but hardly anything about it in this forum
in /opt/var/log/lighttpd/error.log
2022-04-15 03:05:34: (../src/server.c.1568) server started (lighttpd/1.4.64)
2022-04-15 03:05:34: (../src/gw_backend.c.1619) invalid "bin-path" => "/opt/bin/php-fcgi" (check that file exists, is regular file, and is executable by lighttpd)
2022-04-15 03:05:34: (../src/gw_backend.c.530) connect /tmp/php-fcgi.sock-0: Connection refused
2022-04-15 03:05:34: (../src/gw_backend.c.373) child exited: 2 unix:/tmp/php-fcgi.sock-0
2022-04-15 03:05:34: (../src/gw_backend.c.656) gw-backend failed to start: /opt/bin/php-fcgi
2022-04-15 03:05:34: (../src/gw_backend.c.658) If you're trying to run your app as a FastCGI backend, make sure you're using the FastCGI-enabled version. If this is PHP on Gentoo, add 'fastcgi' to the USE flags. If this is PHP, try removing the bytecode caches for now and try again.
2022-04-15 03:05:34: (../src/gw_backend.c.1700) [ERROR]: spawning gw failed.
2022-04-15 03:05:34: (../src/server.c.1572) Configuration of plugins failed. Going down.
Have to ad that rtorrent has been working fine for five years on my RT-AC3200 running Merlin.
I am installing rutorrent on my new router using command:
I have manually configured the router. I have used the flash drive I was using previously in my other router. But that flash drive have been formatted first in Windows and then by amtm. Have not used any backup files. Before installing rtorrent I have installed diversion and skynet. And configured OpenVPN servers and clients.
The RT-AC86U was new from the box. I did reset it before installing Merlin and after.
Has taken me quite some time to set it up the way I wanted. rtorrent was the last step and then this happens... :mad:
php-fcgi doesn't exist. There is a file link php8-fcgi that links to php8-cgi.
SOLVED!!:
Tried the obvious..
I created the symlink inside /opt/bin folder
ln -s php8-cgi php-fcgi
Now error.log is clean. Only says:
2022-04-15 12:36:44: (../src/server.c.1568) server started (lighttpd/1.4.64)
SOLVED!!:
Tried the obvious..
It was my case as well. Thanks for your advice.
