Cannot detect USB drive after firmware upgrade
vkolli
I recently upgraded my RT-AC66U to Merlin 380.69_2. I was running the stock firmware earlier. After the firmware upgrade, USB drive that I was using earlier with the same router is not being detected.
I was using USB 3.0 1TB flash drive for a long time with the same router and have lot of data on the drive. So I cannot reformat it. System log shows the drive as attached (Inateck ASM1153E in the log below) but the GUI shows that no drive is detected.
This is what I see in the system log:
Mar 25 07:43:00 kernel: usb 1-1.1: new high speed USB device using ehci_hcd and address 4
Mar 25 07:43:01 kernel: usb 1-1.1: configuration #1 chosen from 1 choice
Mar 25 07:43:01 kernel: scsi1 : SCSI emulation for USB Mass Storage devices
Mar 25 07:43:03 kernel: scsi 1:0:0:0: Direct-Access Inateck ASM1153E 0 PQ: 0 ANSI: 6
Mar 25 07:43:03 kernel: sd 1:0:0:0: [sda] Attached SCSI removable disk
Mar 25 07:43:03 kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0
I connected a 16GB USB stick to the same USB port and that is detected and mounted OK. After I connect the USB stick I see this in system log:
Mar 25 12:34:18 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 5
Mar 25 12:34:18 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Mar 25 12:34:18 kernel: scsi2 : SCSI emulation for USB Mass Storage devices
Mar 25 12:34:20 kernel: scsi 2:0:0:0: Direct-Access SanDisk Cruzer Facet 1.26 PQ: 0 ANSI: 5
Mar 25 12:34:20 kernel: sd 2:0:0:0: [sdb] 31266816 512-byte hardware sectors (16009 MB)
Mar 25 12:34:20 kernel: sd 2:0:0:0: [sdb] Write Protect is off
Mar 25 12:34:20 kernel: sd 2:0:0:0: [sdb] Assuming drive cache: write through
Mar 25 12:34:20 kernel: sdb: sdb1
Mar 25 12:34:21 kernel: sd 2:0:0:0: [sdb] Attached SCSI removable disk
Mar 25 12:34:21 kernel: sd 2:0:0:0: Attached scsi generic sg1 type 0
Mar 25 12:34:21 hotplug[5371]: USB vfat fs at /dev/sdb1 mounted on /tmp/mnt/NONE
Mar 25 12:34:21 usb: USB vfat fs at /dev/sdb1 mounted on /tmp/mnt/NONE.
Mar 25 12:34:21 rc_service: hotplug 5371:notify_rc restart_nasapps
Mar 25 12:34:21 FTP_Server: daemon is stopped
Mar 25 12:34:21 Samba_Server: smb daemon is stopped
Mar 25 12:34:21 miniupnpd[944]: shutting down MiniUPnPd
Mar 25 12:34:23 Samba_Server: daemon is started
Mar 25 12:34:24 miniupnpd[5415]: HTTP listening on port 33693
Mar 25 12:34:24 miniupnpd[5415]: Listening for NAT-PMP/PCP traffic on port 5351
I spent much time searching for the solution. Any help is appreciated.
Did you remove the external drive before updating?
Just saying...
No I did not ... Didn't occur to me that I have to. Would that have corrupted the disk somehow. I am now trying to access to disk from my mac but not able to see it from my mac either. It was originally formatted as EXT3
Ignore my comment about not being able to access the disk from my mac. Of course I was not able to, since it is EXT3 disk. I am able to see the disk now from my mac.
Any suggestions on how to fix it to be accessed from my ASUS router.
Don't see any resolution to this. Is the takeaway that USB drives HAVE to be disconnected before a firmware upgrade; Whether Merlin or Stock?
