Cannot open router ui when connected to router via vpn
joeejo
I have set up a vpn server on my asus RT-AX86U PRO using merlin 3006.102.4 using guides found here and at asus for the purpose of accessing the router UI from the intenet. I am able to connect to the router via the vpn server from the internet and I am able to ping the router, however when I attempt to access www.asusrouter.com it fails. I have also changed the vpn network to 10.9.8.0 although the routers lan is 192.168.2.0, so there is no overlap. I confirmed that the toggle is set to "both" (lan & internet). I also tried setting the vpn to different ports. In each case when I connect the vpn assignes me 10.9.8.2 and I can ping the router 10.9.8.1 but cannot access the router ui.
If I connect to the vpn server while my pc is on the same lan, I am also able to ping the router (10.9.8.1), indicating I have conected, and I AM able to access the UI at www.asusrouter.com, however the same connection on the same PC outside my lan fails to load the web ui.
I am using openvpn connect as a client from a laptop.
Can anyone suggest what I might have missed or done wrong? Since I can ping the router, I think I have the vpn set up properly, and I feel I am close, but obviously I have something wrong.
Thank you
Here is the router log
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=RT-AX86U_PRO, emailAddress=me@asusrouter.lan
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=client, emailAddress=me@asusrouter.lan
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_VER=3.11.2_dev
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_PLAT=win
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_NCP=2
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_TCPNL=1
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_PROTO=8094
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_MTU=1600
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_CIPHERS=AES-128-CBC:AES-192-CBC:AES-256-CBC:AES-128-GCM:AES-192-GCM:AES-256-GCM:CHACHA20-POLY1305
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_AUTO_SESS=1
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_GUI_VER=OCWindows_3.7.2-4253
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_SSO=webauth,crtext
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 peer info: IV_BS64DL=1
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 TLS: Username/Password authentication succeeded for username 'joe'
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 TLS: tls_multi_process: initial untrusted session promoted to trusted
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 1024 bits RSA, signature: RSA-SHA256, peer temporary key: 253 bits X25519
May 28 22:16:24 Ranch ovpn-server1[30170]: 172.59.130.145:1335 [client] Peer Connection Initiated with [AF_INET]172.59.130.145:1335 (via [AF_INET]67.7.66.44%eth0)
May 28 22:16:24 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 MULTI_sva: pool returned IPv4=10.9.8.2, IPv6=(Not enabled)
May 28 22:16:24 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 MULTI: Learn: 10.9.8.2 -> client/172.59.130.145:1335
May 28 22:16:24 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 MULTI: primary virtual IP for client/172.59.130.145:1335: 10.9.8.2
May 28 22:16:24 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 SENT CONTROL [client]: 'PUSH_REPLY,route 192.168.2.0 255.255.255.0 vpn_gateway 500,redirect-gateway def1,route-gateway 10.9.8.1,topology subnet,ping 15,ping-restart 60,ifconfig 10.9.8.2 255.255.255.0,peer-id 0,cipher AES-256-GCM,protocol-flags cc-exit tls-ekm dyn-tls-crypt,tun-mtu 1500' (status=1)
May 28 22:16:24 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 PUSH: Received control message: 'PUSH_REQUEST'
May 28 22:16:25 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 Data Channel: cipher 'AES-256-GCM', peer-id: 0
May 28 22:16:25 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 Timers: ping 15, ping-restart 120
May 28 22:16:25 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 Protocol options: protocol-flags cc-exit tls-ekm dyn-tls-crypt
May 28 22:16:25 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 IP packet with unknown IP version=0 seen
May 28 22:16:49 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 Delayed exit in 5 seconds
May 28 22:16:55 Ranch ovpn-server1[30170]: client/172.59.130.145:1335 SIGTERM[soft,delayed-exit] received, client-instance exiting
