Since I build this new PC with AMD 3700X and for some reason I cant login the router. I always get "ERR_CONNECTION_TIMED_OUT"
Tried different browser, clear cache, reset network adapter, turned off firewall/antivirus, using http://router.asus.com, cut the power from router for over 1H and reinstalled nwetwork card drivers.
Weird is I can login the router with mine phone/tablet/Old PC. Just this new PC I cant login.
I dont wants to reset the router yet until find out the reason I cant login on this new PC but can on others devices?
Update:
Problem solved. Router setting that only allow specific IP adress to login. Totally forgot it.
Update:
