CD to the right folder
Master3395
Hello.
I was wondering if someone knows how to cd to the right folder.
To run a sh file?
\\RT-AC88U-EC48\entware\share\www\lighttpd\ths\start.sh
I've tried using cd, to get to the folder, but i can't seem to get away from entware...
Admin@RT-AC88U-EC48:/tmp/mnt/256GB-GoFlex/entware/share/www/lighttpd/ths#
chmod 777 start.sh
./start.sh (Makes an error, that i will be showing below.
./start.sh: line 10: syntax error: unexpected end of file (expecting "do")
This is the "start" file.
# /bin/sh
while true
do
echo Starting Bot
node bot.js
echo Restarting Bot in 5 Seconds...
sleep 5
done
I also tried making the bot start there "forever".
But that didn't give me any good
# /bin/sh
forever ./bot.js
At the end i tried this below.
cd /mnt - then ls, cd to the drives mounted point, cd to entware, and so on
Then i did
opkg install findutils-locate && updatedb && locate entware
https://silversunset.net/dbm/tutori...47-restarting-the-bot-automatically-foreverjs
Adding my two files, that i wish to try.
But i can't seem to find a way to use SSH, to get to the right folder, then run the file.
  • start.sh.txt
  • forever.sh.txt
ColinTaylor
Part of the Furniture
Just about everything you've shown is an error of some sort.
1. I can't see in what you've posted the cd command you said you used that didn't work.
2. The start.sh that you run is failing because it has been created in DOS format instead in Linux.
3. The first line of start.sh is incorrect, it should be:
#!/bin/sh
4. The first line of forever.sh is also incorrect because the router doesn't have bash.
Master3395
Below is where my folder with my files is located.
And i had issues cd-ing to it.
But i got a working away, from freenode IRC
cd /mnt
Then i did cd /entware etc so i got to ths#
Then i did
chmod 777 start.sh
And as you said that the first line is wrong, I'm not sure what to post in it.
# /bin/sh
while true
do
echo Starting Bot
node bot.js
sleep 5
done
ColinTaylor
You should correct the errors in points 3. and 4. using the code I showed you.
Then fix the start.sh file with the following command:
dos2unix start.sh
Master3395
Just tried that, got this.
dos2unix start.sh
Master3395
Just installed these
Then i tried re-running your dos2 code.
It returned no info
Master3395
If i do this, i get illegal instructions.
I want the bot to run, and restart only if it stops.
I don't want to restart it every 5 seconds.
It seems like it says in the output, that it restarts every 5 seconds.
But i don't see the bot running at all.
#!/bin/sh
while true
do
echo Starting Bot
node bot.js
echo
sleep 5
done
ColinTaylor
#!/bin/sh
while true
do
echo Starting Bot
node bot.js
echo
sleep 5
done
Also, the "Restarting Bot in 5 Seconds..." line is a syntax error because it should be part of the previous line. That should be creating another error message in your output. The fact that it isn't makes me think that you are not posting a real contents of the script, or you are running the script in a different way now.
Master3395
It is starting and restarting every 5 seconds, but i can't see that it runs, as it restarts every 5 seconds heh
And you were right. restart part was supposed to be on the side of the echo.
ColinTaylor
Like I said, the "Illegal instruction" message means that the "node bot.js" command is crashing. Probably because it is not compatible with your router.
Master3395
I no longer get the illegal instruction error.
It was because of a syntax error i made.
But even if it says it's going to take 5k seconds, i don't see it running on the discord.
So i don't think the bot is running at all
Or it can't show to the world.
dave14305
Are you editing the files in ssh or over the Samba share in Windows?
Master3395
All files except start and forever is using samba.
The other 2 is done in ssh.
Master3395
That might be it.
But I'm not sure why it says illegal instruction now.
I'm guessing that the first time you created those files was over Samba which is why they were in DOS format.
