Chromecast dont work, help please.
jonas
Hello
i have ac5300 router and chromecast is not working my firmware is 380.68_4. i can see that they are connected but i cant see them o my phones or computer. i hope some off you can help.
Go to Wireless>Professional
For EACH Band (2.4GHz, 5GHz-1 and 5GHz-2) make sure to enable IGMP Snooping.
Does it work?
Same issue with GT-AC5300 IGMP Enabled - AP Disabled - Upnp is Enabled
Any other suggestions?
Sorry no. On RT-AC5300 it is not enabled by default causing Chromecast issues. On GT-AC5300 it is enabled by default and I never had any issues with Chromecast on this router.
Had similar CCA connection issues.
Disabled "Airtime fairness" for 2.4Ghz and 5Ghz band in Wireless>Professional, and suddenly all my Chromecasts work perfectly fine.
They are visible immediately and connect stable.
I have IGMP Snooping disabled since a week, and they still work fine, but IGMP Snooping may help.
