Clear notification exclamation mark
Slickepinnen
With the lastest firmware I get the yellow exclamation mark notifying about the ftp issue.Is there any way to clear it or will it keep blinking until the next firmware update? AC68U
What does it say when you hover over it?
Glad you solved it (and let others know how to do it too).
I have the same issue. Can you point me to the specific menu commands to "disable user accounts and re-enable"?
Nevermind, I figured it out. For other newbies, it is at:
USB Applications / Servers Center / FTP Share / Share without account
To re-enable, click "Share with account".
