Hi guys!
So I have an AX86S as the main unit and an AC68U as a mesh node.
Basically when I'm connected to the AX, I CAN NOT ping (even using IP address) the nodes that are connected to the AC (getting 17 nodes via LAN-scan).
When I'm connected to the AC, then I CAN ping all nodes (either connected to the AX or AC, totally 22 nodes via LAN-scan).
Latest Merlin FW, no "special" settings. Restarted, tweaked, nothing solved the issue for now.
Any idea what should I check?
Thanks in advance!
Thanks in advance!
