What OPNVPN says (today): "While protecting the Internet traffic on various hot-spots and insecure networks is a valid use case, we are concerned Cloudflare's reimplementation of the WireGuard code has not reached maturity yet."
My 2 cents: I haven't (yet) seen any substantial reports of anyone cracking into a wireguard configured network. Maybe that's because it's still new and maybe it's because it is difficult to accomplish (and maybe, I'm not seeing the source material, which would be appreciated if someone posted).
It's based on WG with some n0-touch client config...
I played around with it - sometimes works, sometimes not on iOS - I think sometimes it gets confused when it hops from LTE back to the LAN connection..
I ended up disabling it because of the battery hit on my older iPhone6s - with Warp enabled, I couldn't make it thru the day...
I just set up my RT-AC86U with Warp+ from CloudFlare and thought I'd share how in case anyone else is interested. This is only for RT-AC86U (and RT-AX88U I assume though haven't tested) since it relies on the experimental WireGuard posted by @Odkrys. Here are the setup instructions: Sign up for...
