edgezero
Hello! Does anyone have an idea how can I *completely* disable legacy rates for my AC88U? I have set 2.4Ghz wireless mode to N Only however pcap shows beacons are still sent at 1Mb/s. I don't have b/g devices on my network.
802.11 radio information
PHY type: 802.11b (4)
Data rate: 1.0 Mb/s
Channel: 11
Frequency: 2462MHz
Signal strength (dBm): -17dBm
Noise level (dBm): -88dBm
Signal/noise ratio (dB): 71dB
TSF timestamp: 3046454662825133
[Duration: 2192µs]
This does not happen at 5Ghz:
PHY type: 802.11a (5)
Turbo type: Dynamic turbo (2)
Data rate: 6.0 Mb/s
Channel: 36
Frequency: 5180MHz
Signal strength (dBm): -22dBm
Noise level (dBm): -90dBm
Signal/noise ratio (dB): 68dB
TSF timestamp: 899821418350104
[Duration: 352µs]
I use Merlin 384.12. I have seen this option in Cisco routers but I'm wondering if this is can also be done in Asus via custom firmware or config file or request this to RMerlin?
Why do I (or possibly you) want this? Optimization, tweaks and granular controls!!
Thanks!
Data rate: 1.0 Mb/s
Channel: 11
Frequency: 2462MHz
[Duration: 2192µs]
Data rate: 6.0 Mb/s
Channel: 36
Frequency: 5180MHz
[Duration: 352µs]
Thanks!
