Configuring Open VPN RT-AC68U
lydnsn
Good evening. If anyone has detailed instructions on setting up open vpn on the rt-ac68u could you kindly post it here. I have tried to do it following their instructions and using their default settings. It connects ok but i cant access anything remotely . I also cant access the internet while i'm connected. I am thinking it might be a problem with ip conflicts but i dont know enough about it to be sure Thank You.
please be more specific. your router supports openvpn client and server. are you saying openvpn client connecting to a VPN provider doesn't work? or are you saying that when you connect to an openvpn server you've created it doesn't work?
I am using the open vpn server and client within the router. I set up the client and server as per the instructions using the default settings. It says it creates an ovpn configuration file based on my settings.I set up the server and then I exported the file and saved it. Once i finished doing that i uploaded the ovpn file to the client and then turned it on . Then i installed open vpn on the computer i want to use to connect to the server . On my computer i added the opvn file to the config folder as per the instructions. It appears to connect ok but i cant access anything or get on the internet. I can connect to my router just fine though, thats how i know its connected.
Tried those settings and still not working.
Here are log files from router.
Jun 13 19:15:02 openvpn[1046]: 70.50.139.229:60906 TLS: Username/Password authentication succeeded for username 'vivian'
Jun 13 19:15:02 openvpn[1046]: 70.50.139.229:60906 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jun 13 19:15:02 openvpn[1046]: 70.50.139.229:60906 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jun 13 19:15:02 openvpn[1046]: 70.50.139.229:60906 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jun 13 19:15:02 openvpn[1046]: 70.50.139.229:60906 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jun 13 19:15:02 openvpn[1046]: 70.50.139.229:60906 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Jun 13 19:15:02 openvpn[1046]: 70.50.139.229:60906 [client] Peer Connection Initiated with [AF_INET]70.50.139.229:60906
Jun 13 19:15:02 openvpn[1046]: client/70.50.139.229:60906 MULTI_sva: pool returned IPv4=10.8.0.6, IPv6=(Not enabled)
Jun 13 19:15:02 openvpn[1046]: client/70.50.139.229:60906 MULTI: Learn: 10.8.0.6 -> client/70.50.139.229:60906
Jun 13 19:15:02 openvpn[1046]: client/70.50.139.229:60906 MULTI: primary virtual IP for client/70.50.139.229:60906: 10.8.0.6
Jun 13 19:15:05 openvpn[1046]: client/70.50.139.229:60906 PUSH: Received control message: 'PUSH_REQUEST'
Jun 13 19:15:05 openvpn[1046]: client/70.50.139.229:60906 send_push_reply(): safe_cap=940
Jun 13 19:15:05 openvpn[1046]: client/70.50.139.229:60906 SENT CONTROL [client]: 'PUSH_REPLY,route 192.168.192.0 255.255.255.0,route 10.8.0.1,topology net30,ping 15,ping-restart 60,ifconfig 10.8.0.6 10.8.0.5' (status=1)
Jun 13 19:20:22 openvpn[1046]: 70.50.139.229:61101 TLS: Initial packet from [AF_INET]70.50.139.229:61101, sid=065a915f 7f7bd77f
Jun 13 19:20:22 openvpn[1046]: 70.50.139.229:61101 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, emailAddress=me@myhost.mydomain
Jun 13 19:20:22 openvpn[1046]: 70.50.139.229:61101 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, CN=client, emailAddress=me@myhost.mydomain
Jun 13 19:20:23 openvpn[1046]: 70.50.139.229:61101 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
Jun 13 19:20:23 openvpn[1046]: 70.50.139.229:61101 TLS: Username/Password authentication succeeded for username 'vivian'
Jun 13 19:20:23 openvpn[1046]: 70.50.139.229:61101 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jun 13 19:20:23 openvpn[1046]: 70.50.139.229:61101 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jun 13 19:20:23 openvpn[1046]: 70.50.139.229:61101 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jun 13 19:20:23 openvpn[1046]: 70.50.139.229:61101 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jun 13 19:20:23 openvpn[1046]: 70.50.139.229:61101 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Jun 13 19:20:23 openvpn[1046]: 70.50.139.229:61101 [client] Peer Connection Initiated with [AF_INET]70.50.139.229:61101
Jun 13 19:20:23 openvpn[1046]: client/70.50.139.229:61101 MULTI_sva: pool returned IPv4=10.8.0.10, IPv6=(Not enabled)
Jun 13 19:20:23 openvpn[1046]: client/70.50.139.229:61101 MULTI: Learn: 10.8.0.10 -> client/70.50.139.229:61101
Jun 13 19:20:23 openvpn[1046]: client/70.50.139.229:61101 MULTI: primary virtual IP for client/70.50.139.229:61101: 10.8.0.10
Jun 13 19:20:25 openvpn[1046]: client/70.50.139.229:61101 PUSH: Received control message: 'PUSH_REQUEST'
Jun 13 19:20:25 openvpn[1046]: client/70.50.139.229:61101 send_push_reply(): safe_cap=940
Jun 13 19:20:25 openvpn[1046]: client/70.50.139.229:61101 SENT CONTROL [client]: 'PUSH_REPLY,route 192.168.192.0 255.255.255.0,route 10.8.0.1,topology net30,ping 15,ping-restart 60,ifconfig 10.8.0.10 10.8.0.9' (status=1)
Jun 13 19:20:58 openvpn[1046]: client/70.50.139.229:60906 [client] Inactivity timeout (--ping-restart), restarting
Jun 13 19:20:58 openvpn[1046]: client/70.50.139.229:60906 SIGUSR1[soft,ping-restart] received, client-instance restarting
Jun 13 19:30:20 openvpn[1046]: client/70.50.139.229:61101 [client] Inactivity timeout (--ping-restart), restarting
Jun 13 19:30:20 openvpn[1046]: client/70.50.139.229:61101 SIGUSR1[soft,ping-restart] received, client-instance restarting
Jun 13 19:44:33 dnsmasq-dhcp[483]: DHCPREQUEST(br0) 192.168.192.60 28:e3:47:28:36:60
Jun 13 19:44:33 dnsmasq-dhcp[483]: DHCPACK(br0) 192.168.192.60 28:e3:47:28:36:60 Lenovo-PC
Jun 13 19:48:44 dnsmasq-dhcp[483]: DHCPREQUEST(br0) 192.168.192.60 28:e3:47:28:36:60
Jun 13 19:48:44 dnsmasq-dhcp[483]: DHCPACK(br0) 192.168.192.60 28:e3:47:28:36:60 Lenovo-PC
I think I am having a similar problem. Just upgraded my 68U to the Merlin 378.54_2 firmware and made the siwtch from PPTP VPN to OpenVPN. With the PPTP VPN, I could connect to my router while out on the road and access resources inside my network...worked flawlessly. With the new OpenVPN...I can connect fine but once connected...I can't access anything inside my network. What am I doing wrong?
It would help if you specified what client/app you are using to connect to the server.
direct clients to redirect internet traffic should be on?
also this doesnt look good.
I am no expert, my server config on the router is different then martinr and yours. Here is what I did different:
I used TAP instead of TUN, (push lan to clients will be missing)
Firewall - External only
Allocate from DHCP = Yes,
Respond to DNS = No,
Manage Client-Specific Options = Yes --> Allow Client -Client = Yes, Allow only specified clients = No
I should mention my android with 4.1.? could not use TAP natively. I had to purchase a app on google play that has OpenVPN with TAP. My laptop with openvpn (client) connects just fine (TAP).
Also I should mention last year when I was messing around with being double NAT'd I tried using a raspi to run openvpn server. Setting it up and depending on the encryption it would take aprox 10-20 minutes to generate keys. I would like to know how the AC68U generates it so fast. :)
EDIT: nevermind already answered by RMerlin http://www.snbforums.com/threads/asuswrt-merlin-378-54_2-is-now-available.24902/page-12#post-188330
