Confounded: Asus AC88U and AC68P with AiMesh-- "invalid password"
dial911
Gear:
AC88U
Merlin 384.17
Main router
Running separate 2.4Ghz and 5Ghz networks
AC68U
Merlin 384.17
AiMesh router
I have been running the AC88U as my main router and an AC66P as an access point. I recently purchased an AC68U so that could take advantage of AiMesh and then retire the AC66U.
I went ahead and successfully upgraded the AC68U to Merlin 384.17. I then did a power on + WPS button to get a full factory reset. I logged into the AC88U and searched, discovered, and according to the interface had successfully added the AC68U as an AiMesh node.
I then clicked on the AC68U and went to “More config” and set the connection priority to Ethernet via the dropdown (as I don’t have good wireless coverage from the AC88U to the area where it will be placed). I then powered the router off and placed and powered it in its new location. I connected the Ethernet connection to the WAN port of the AC68U and also connected a device to the switch port.
After waiting several minutes for the AC68U to boot, it eventually showed as “online” as an AiMesh node when I logged into the AC88U. It showed the connection as wired. It also listed the one client—the one that was connected via the switch port of the AC68U.
The issue:
I cannot log into the wifi when in the area and connected to the AiMesh AC68U. I can see devices attempting to log in, but they are unsuccessful. They will briefly appear in the “client” list as wireless connections, and then disappear.
I can identify via signal strength both the 2.4Gz and 5Ghz networks being broadcast by the AC68u. If I try to log in via my iPhone or laptop, I get a message, “Incorrect password.” I have carefully typed and checked the password and I know it to be correct, but same result. I have tried changing the wireless password on the AC88U, but no luck.
I went back and resent both the AC88U and AC68U to factory default and repeated the process, and still no luck. I’m confounded. What can I do to troubleshoot or try to fix the issue. I have searched the forums and have not been able to find anything definitive as the answer. In the meantime, I’ve just put the AC66U back in service as a regular access point without issue (running Merlin 380.70).
Thanks in advance for any thoughts or advice!
Have you done / checked the 'usual configuration issues and nuances?
***IMPORTANT*** Use the 'Forget This Network' on your devices and re-enter passphrase. You may even want to try a new SSID since some (stupid) clients never really forget all of the low level configuration exchanged between client and router
No Special Characters in SSID
No Smart Connect (bad experience with SC enabled on 86U when the 68U/P does not support SC
Fixed Channels and 2.4 set to 20MHz width
Separate SSIDs for 2.4 and 5
(For both 2.4 and 5...)
Universal Beamforming - Disabled
Airtime Fairness - Disabled
TX Bursting - Disabled
Blue_Cave router with one RT-AC68U node.
Same exact issues here. Difference is the node seems to work fine for 12-24h then all of a sudden: "Incorrect Password". Done the forget password / reset network settings on iDevices but no love. If anyone finds a solution please post.
PS: I used the correct password and if I walk over to the Blue_Cave the device jumps right back on without issue so seems isolated to the node vicinity.
Very frustrating.
Anyone found the solution? I'm having the same problem, also with AX and AC routers. It worked fine after the initial installation, but this problem started occurring with iPhones the next day after I changed some settings. It's either invalid password or cannot access. Only with the Node.
The changes I made were enabling DNS over TLS, enabling DNSSEC, changed from WPA2 to WPA2 / WPA3-Personal, disabled 11b. I tried reversing them, I even did a reset to the Node and re-added it, but nothing solves the issue.
