Confusion about IP assignments on RT-AC88U with Dish Hopper/Joey Wifi
azbruno
I have a Dish Hopper with Sling and Joey setup using Wifi. The Hopper is the main set top box and the Joey is the smaller box on the second TV.
I have found three different MAC addresses associated with this setup. For brevity, I will refer to them only by the last byte... :7C, :7A and :60.
My Router is configured as follows...
The LAN DHCP Assignments are set up to manually assign IP addresses to the three MAC addresses...
:7C = 192.168.1.124
:60 = 192.168.1.125
:7A = 192.168.1.126
The Hopper connects to my second 5GHz Guest network, which uses a MAC Filter that accepts the three MAC addresses.
Looking at the Hopper network connection on the TV, it is connected to the correct network and shows the wireless MAC address (:7C) and the MoCA address (:7A), but the IP is actually 192.168.1.213 (not a manual assignment). Looking at the Joey on the TV, it shows the IP address as 192.168.1.125 and MAC address :60. But then looking at the router's network map, it is showing the Wifi MAC address :7C with IP 192.168.1.213 under the 5GHz guest network interface with MAC and IP binding turned off. It also shows the Joey MAC :60 as IP 192.168.1.125, but it is listed under the WIRED interface.
This is very confusing. Why is MAC address :7C not manually assigned to 192.168.1.124? And why is IP 192.168.1.125 showing as wired?
B OpenVPN Client not reconnecting when server goes away RT-AC88U ASUSWRT - Official 1
