Constant DDNS refreshes
RocketJSquirrel
This is new. Suddenly, my AC68U running 386.5_2 is logging constant DDNS refreshes. Like every 30 seconds. Ideas?
Jun 14 18:09:03 watchdog: start ddns.
Jun 14 18:09:03 rc_service: watchdog 231:notify_rc start_ddns watchdog
Jun 14 18:09:03 start_ddns: IP address, server and hostname have not changed since the last update.
Jun 14 18:09:33 watchdog: start ddns.
Jun 14 18:09:33 rc_service: watchdog 231:notify_rc start_ddns watchdog
Jun 14 18:09:33 start_ddns: IP address, server and hostname have not changed since the last update.
Jun 14 18:10:03 watchdog: start ddns.
Jun 14 18:10:03 rc_service: watchdog 231:notify_rc start_ddns watchdog
Jun 14 18:10:03 start_ddns: IP address, server and hostname have not changed since the last update.
Jun 14 18:10:33 watchdog: DDNS Recover Time reached, recover DDNS Retry.
Jun 14 18:10:33 watchdog: start ddns.
Jun 14 18:10:33 rc_service: watchdog 231:notify_rc start_ddns watchdog
Jun 14 18:10:33 start_ddns: IP address, server and hostname have not changed since the last update.
Jun 14 18:11:03 watchdog: start ddns.
Jun 14 18:11:03 rc_service: watchdog 231:notify_rc start_ddns watchdog
Jun 14 18:11:03 start_ddns: IP address, server and hostname have not changed since the last update.
Jun 14 18:11:33 watchdog: start ddns.
Jun 14 18:11:33 rc_service: watchdog 231:notify_rc start_ddns watchdog
Jun 14 18:11:33 start_ddns: IP address, server and hostname have not changed since the last update.
Jun 14 18:12:03 watchdog: start ddns.
Jun 14 18:12:03 rc_service: watchdog 231:notify_rc start_ddns watchdog
Jun 14 18:12:03 start_ddns: IP address, server and hostname have not changed since the last update.
Have you tried a reboot? Sometimes the simplest answer just works :)
Reboot fixed it. Duh. No dual WAN. Sorry for the waste of forum bandwidth.
I occasionally get constant DDNS refreshes also, same log entries as OP, AX86U on 386.7.2 and also on previous revs. I do use Let's Encrypt. Not sure what starts it; by the time I look the log is filled with them, 30 sec apart.
FYI, I was able to stop them by just going to the GUI WAN DDNS tab, changing nothing, click Apply. This appears to force a DDNS update, clears the DDNS cache, starts Inadyn. After doing this, the constant DDNS refreshes are gone. Did NOT have to reboot.
  • Like
Reactions: Ngr
Thanks for the reply. I continue to see these from time to time also. Good to have a better solution than rebooting.
So I'm here in October 2022 because I started seeing this error and and started searching the forms for it. Mine was caused by an internet outage. Once the modem regained a WAN connection, the error started. Kind of makes sense.
Hitting apply on the DDNS page worked as detailed above. Thank you for the solution.
