Constant unwanted traffic to dns.msftncsi.com from RT-AC66U
This is really a bit of a necro-thread, and I think @ColinTaylor put it to bed in the post you've responded to. Quite seriously, I fail to see how a ONCE PER MINUTE PING can really be considered an issue!
I didn't quote respond to them did I?
So once per minute is clogging up my pihole log like others have said, that's not really the core issue here. The router constantly doing this when I personally don't want it to and have told it not to, is the issue, since it shouldn't be doing it. Id rather my network not constantly ping microsoft.
Also my mistake its twice per minute (21,327 total entries so far in less then 24 hours).
Hi, I wonder if anyone can help me. I am also getting the same issue. I have changed the nvram parameters, and also edited the registry on the windows machine and also changed the hosts file to go to 0.0.0.0, yet my pihole log is pinging this domain once every minute.
Which router model?
What firmware version?
Which nvram parameters did you change and to what?
What are your router's WAN DNS servers? They should be pointing to an external server and not a local PiHole.
Which router model?
Model:TUF GAMING AX4200
Firmware Version:3.0.0.4.388_33903
Nvram changes:
nvram set dns_probe_content=0.0.0.0
nvram set dns_probe_host=""
nvram commit
reboot
nvram show | grep dns_probe:
dns_probe=0
size: 43144 bytes (210808 left)
dns_probe_timeout=1
dns_probe_host=
My WAN DNS is my pihole what's exactly wrong with that? When there is an ability to set what ever DNS you wish there? Giving examples like google and cloudflare as options?
OK your options are more limited then compared to Merlin's firmware.
The WAN DNS is what the router uses for itself (e.g. checking whether the internet connection is working, NTP, etc). Having this traffic going through and being reliant on a PiHole is not usually desirable. Typically the LAN DNS server settings is where you would put your clients' DNS servers (e.g. your PiHole address). Try that and if it doesn't solve your problem come back to us.
How have you configured your router for Pi-Hole usage? Did you put the Pi-Hole IP addresses into the router's WAN DNS field(s)? If so that is not the recommended setting according to Pi-Hole. Put the Pi-Hole IP into the LAN DHCP DNS field(s).
However, we recommend to setup Pi-hole always as DNS server for your LAN! If you do so, Pi-hole's IP is distributed as DNS server via DHCP to your network clients. Each client will directly send their queries to Pi-hole and will be shown individually in Pi-hole's web interface. Additionally, you can use the group management features.
Putting the Pi-Hole IP into the WAN DNS field may cause a feedback loop of requests depending on the Pi-Hole settings, which can flood the network with DNS requests, crippling the local network, and fill the Pi-Hole log. See the following link for one way to setup Pi-Hole on Asus routers.
Note: Depending on the Asus-Merlin firmware version there is a change in the DNS Director operation in the latest Asus-Merlin firmware which is not reflected in the previous link that gives an example of DNS Director configuration with Pi-Hole.
Pardon my ignorance but the router says "Assign a DNS service to improve security, block advertisement and gain faster performance." And gives options similar to a pihole for instance to block ads etc network wide? Wouldn't I prefer to do that before the router vs after?
This is a problem on the device side - when I was doing IoT development over 4g a couple of years back, there was a concern about how Iot devices would behave if the WAN connection had difficulty - e.g. if the first attempt failed to connect, how aggressively the firmware would try to connect after the failed attempt.
Much of this goes towards the IoT battery, so one should "spiral" out the approach - e.g. move from once per minute maybe out to 5 mins, then 10 up to 4 hours - key thing is to let it connect.
And then there's the discussion about how often to connect - it's one thing for a desktop to check connectivity, it's another for something like a security system...
And then you have broken things - I've got a Nest Home Mini - and it can get into a state where it's pinging gstatic.com every 15 seconds...
Point here - some traffic is actually reasonable if it helps the user experience, but many times it gets out of hand...
randomly adding firewall rules to block all traffic might not be the best approach here
Yes, so that's why you set your PiHole address in the LAN DNS settings as @bennor and I said.
I think I was misunderstanding. So if I set it to lan in the dhcp the devices use the pihole DNS I understand that part but the router itself before it gets wan from my ISP isn't being filtered right? Wouldn't it be better from a security and performance perspective to use a custom DNS vs my isps?
... but the router itself before it gets wan from my ISP isn't being filtered right?
Correct.
The router's own use of DNS is minimal. It's not as if it's browsing websites. But if you don't trust your ISP's DNS servers you can use some other public DNS servers.
Your ISP's DNS servers are usually faster than other public DNS servers like Google and serve CDN better.
"security and performance" might be an issue for your LAN clients but that's dependant on how you've configured your PiHole and what upstream servers the PiHole is using.
The router's own use of DNS is minimal. It's not as if it's browsing websites. But if you don't trust your ISP's DNS servers you can use some other public DNS servers. "security and performance" might be an issue for your LAN clients but that's dependant on how you've configured your PiHole and what servers the PiHole is using.
IIRC - some of the router, esp if configured for dual wan (active/active or active/fallback) would hit a DNS server to check connectivity there - was that the WANDUCK process?
I don't use dual wan.
Okay so imma just use cloudflare as my wan DNS.
It no longer clogs my pihole ofc.
My next question so I can wrap my head around this the dhcp server dishing out my pihole as a DNS bypasses the wan DNS? As would me setting the dhcp static to cloudflare? As in it doesn't go through the pihole then through the routers wan DNS then to the www?
So the wan DNS is purely for the router only? I'm a little confused NGL 😅
Also PS edit:
Now the dhcp of the router assigns the correct DNS but as primary and secondary is the router gateway IP, which I assume then uses the WAN DNS as a failsafe? I only want it to use my pihole.
Nvm I'm blind - Advertise router's IP in addition to user-specified DNS wasnt set as no.
Also PS edit:
The one downside to using the Pi-Hole as the only DNS on your LAN is the Raspberry Pi can be more prone to failure than the router if Pi-Hole is on a RPI. The RPI uses a Micro SD card which can fail suddenly. If that happens your LAN clients will be without DNS. For Failsafe operation use two RPI's or put Pi-Hole on another always up client. Or use the router for the second DNS and set it to use a filtering DNS service such as Cloudflare Security, Quad9 or better yet Control D. I have a RPI 3b+ that runs Stubby and DNSMASQ with Stubby set to go to Control D (76.76.2.2, 76.76.10.2) and the router set to the same. If my RPI fails the router DNS will still work. Sounds like overkill but I feel I get as good DNS protection/add blocking with the Control D service as running Pi-Hole. And, I do not have to keep the Pi-Hole updated.
