Thanks sfx2000 and Pierino for your prompt replies. I was considering getting a faster router to improve bufferbloat rating as reported on DSLreport speedtest. After replacing my failing 4 year old XyZEL Q1000z modem/router with the newer Technicolor C2000T, my bufferbloat is a "F" or "D" grade. It was rated "A" or "B" before the switch.
I did not have QoS enabled before but maybe I need to now. Currently on 12/0.6 Mbps CenturyLink DSL service. The desktop that I am typing from is hard wired ethernet into the modem's LAN port and I still get poor bufferbloat rating. Just curious if I am heading in the right direction by getting a better router? Thanks.
Technicolor for WiFi ???
At 12Mbps, a $50 router should be fine. I use/suggest ASUS.
Can you afford/get cable modem service instead of last-century poky DSL?
Thanks for your thoughtful comments. I also do not game so a bad grade on bufferbloat does not appear to affect my internet use such as web pages, email and streaming HD content to the HTPC. I tried QoS on or off but there appears to be no change.I have to agree about getting speedier internet, most likely broadband instead of DSL. Anyways, I have 3 nice speedy routers and they all get "F" for bufferbloat unless I turn on QoS specifically for that. Then they get an "A". However, I'm not a gamer, so the poor performance on the bufferbloat test makes no apparent difference to me in perceived speed on the internet, and I've never been one for trying to get good grades just to have good grades *smile*. What really does matter, though, is my download/upload speeds, that makes a much larger difference in perceived speed on the internet.
Nothing wrong with getting a better router, but what I'm saying is that you won't see any benefit from that unless your current router just isn't doing the job. You do say that it's failing, so sounds like it's time to upgrade. Wouldn't worry about getting an expensive router for 12/.6 internet download speed, though...unless you plan on upgrading your internet speed in the near future *smile*.
| Thread starter | Title | Forum | Replies | Date |
Netgear to Asux AX + merlin, please suggest model | Wi-Fi Buying Advice | 4 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
