CPU temp High RT-AC5300
Joram
I am runnig merlin 380.57 on my RT-ac5300, and my cpu temp is never under 81.
Any tips or suggestions on what to do ?
What makes you think the CPU temp is abnormally high?
I don't know what normal temp is. Keep in mind the BCM4709C CPU is clocked at 1.4 GHz, faster than the BCM4709 in earlier ASUS routers.
If the product is properly designed, it will shut down before temperature could harm the chip.
My AC3200 was also doing that kind of temp. So what I did is I buy a cheap laptop cooler with usb powered big fan. Placed the router on top of it.
All the temps dropped at least 10C.
Hopefully it's not an issue. I've been having constant disconnects with my laptop with the latest firmware from Asus, but when I changed to the Merlin 380.57 firmware all of the connection issues disappeared. So I am glad for that.
