CT-8 AiMesh setup backhaul issue
freten
Hi, I have had two CT-8 units since may and they have been working fairly good. Not problem-free but acceptable, until yesterday. By coincidence I noted in the web interface that the signal quality suddenly had changed from "Excellent" to "Weak". The node is about 4-5 meters away from the router with 2 walls in between, but signal strength has never been a problem. Digging in to this I realize that the backhaul channel, which is a dedicated 5GHz channel, suddenly is a 2,4GHz channel. The strange thing is that nothing has been moved or added. I don't even see how the 2,4 channel can be a backhaul channel, it is not supposed to work. I have reset and restarted the node twice, also restarted the router of course but it stays the same. Anyone bumped in to this? Cant find anything online. Have set a support request to ASUS but I guess it will take time.....
