Custom login that will survive a WPS rest?
dobbe
Hello
Is there a way to somehow make it tougher to circumvent parental controls and access restrictions by using a non-standard login and perhaps save the parental controls config to non-volatile ram?
Something that can survive a reset to defaults?
Thanks in advance
Everything is saved to nvram. You can't prevent someone from pressing the reset button to erase the whole configuration.
To be honest, if your kids are doing this to bypass parental control, you need more to have a serious talk with them than having a router able to be 100$ fool proof (which you can't - any device that is physically accessible cannot be secured in any way).
