DDNS setup
calzor suzay
I have amtm and diversion running with pixelserv-tls.
I'd like to setup up DDNS via asus.com and use the free letsencrpyt cert process but there's a server certificate at the bottom and not sure if this is an issue or not.
Status :
Active
Issued to :
192.168.2.1
SAN :
192.168.2.1 router.asus.com RT-AC86U-4570
Issued by :
192.168.2.1
Expires on :
2028/5/5
Under Administration > System > Local access config where you'd normal export the cert it re-directs you back to the DDNS page, if I export the cert there it gives me a cert.pem and key.pem file.
Shall I just go ahead and attempt to set the DDNS settings up?
Any ideas?
Not keen on just trying this then breaking a cert etc.
