Dear RMERLIN please add timed reboot feature...
dolftb
HI,
I have the lastest .34-2 firmware running on both Router and media bridge. If I don't reboot router every few days the transfer speeds of large files will drop from 45mb/s to 25-30 mb/s
This has been going on for months will all the recent firmware versions. I don't need to reboot the media bridge just the router.
All of my devices have static Ip's with exception to my 2 laptops and smartphone for which I instructed router to assign a specific IP to mac addresses . This because if have had many conflicts before. This however should not have a bearing on the issue above.
I prefer this firmware over DD-WRT however that does have a reboot fuction that can been designated. Would it be much trouble to implicate this ??/
Router already has this feature. Just use CRON, and bash script as described in the readme file.
script file should consist: (any name but the extension sh, and chmod 777*)
#!bin/sh
reboot
*read readme for more info.
Try adding a cron job.
Edit (or create) the file /jffs/scripts/services-start
add the following line:
cru a dailyReboot "0 1 * * * /sbin/reboot"
I would reboot after adding this line. It then sets up a cron job that, at 1AM in the morning, every day, will execute the reboot command.
Should work...
Thanks but where to put....
Should work...
Thanks for your help. So when I copy the line you gave me where do I paste it into ?
Sorry I am a intermediate when it come to these things...
Ok, try this.
Open a telnet or ssh session and get to the command prompt.
Mine shows:
admin@RT-AC68U: /tmp/home/root#
at the commmand prompt type these commands exactly how it is here:
echo "#!/bin/sh" > /jffs/scripts/services-start
echo "cru a dailyReboot \"0 1 * * * /sbin/reboot\"" >> /jffs/scripts/services-start
Now, check and make sure the file is created and has this in it:
Type this cat command at the command prompt:
cat /jffs/scripts/services-start
It should show this:
#!/bin/sh
If so, your good to go. Now we need to make it executable. So, enter this command:
chmod a+x /jffs/scripts/services-start
You will now need to reboot the router for the command to actually execute. So, reboot.
After booting, I would telnet or ssh back into the router and see if it is actually running. So, type this at the command prompt:
cru l
0 1 * * * /sbin/reboot #dailyReboot#
Good luck
