Detecting dead NordVPN tunnel quickly?
You may have to try a different provider than NordVPN. I believe the relevant parameters would be ping and ping-restart. But those parameters are overwritten with the values pushed from the server (ping 60 and ping-restart 180). You can use pull-filter ignore "ping-restart". That allows you to then change ping-restart locally to something like 60 seconds, but I found if you do that the client continuously restarts itself every 60 seconds. It seems like the server doesn't like you messing with those values. YMMV
Yes, that is also my experience when I "adjusted" the values, although using --keepalive 2 10.
That set me onto the idea of using a dual WAN router I happen to have, and let it do the failover between two WAN ports, connected to two LAN ports (with different VPNs) on the main router. Messy, as I say, but I think the router WAN failover is quicker.
Because I am in country X, and the company expects calls/login from its home country Y
Then either find a different job in country X or move to Country "y"
You'd be surprised how many North Koreans are working in the US these days for IT roles...
I'm told they are actually pretty good on a professional level
Try ProtonVPN for a month (they even have a Black Friday deal right now). WireGuard might be more stable for your type of usage since it won't involve regular key rotations.
That way if it`s even worse, you can just switch back to your existing NordVPN service. If it works well, you can extend the service to a full year.
Thanks! I may well do that! :)
But quick question: is the "remote-random" and several servers in one config tested and working? The setup seems pretty simple, but both RT-AX86U PRO with stock, and an old RT-AC68U with Merlin only ever looks at the last server in the list. (And when I put a "false" server in (to test) the router never moves to another server.)
In the NordVPN there is even a "remote-random" line in the standard config, even with only one server IP. I just can't get it to work.
No idea, I never tested that in a router environment. I thought that it generally required different certificates for each server, which means you can't use that.
