DFS Channels AX88U, 386.1_2
Sptz
I have a question regarding DFS channels with an AX88U in the UK.
First of all, selectable channels don't go over 140, I'm guessing that's the maximum in the UK?
Second, I have it setup to allow 160mhz and auto select as seen below. The current channel is 100, which I'm guessing is in the DFS range? How would I know if it is, isn't or and if it detects radar signal?
Thanks!
Correct. Although technically there was a UK regulation change in 2017 that allows channels >140 but don't expect to see those appear any time soon.
All the channels from 52 upwards are DFS.
I think it shows a message in the router's system log.
