DHCP ip address lost after reboot
rob10k8
I just updated to firmware 384.13 and I lost all of my DHCP reservations that I had set up.
I tried setting up again, but any time I reboot the router, I get "no data in table".
I reverted back to 384.12, but have the same issue, and I have no clue what could be going on (I am adding the IP address and hitting "apply", as I'm sure that is a common mistake).
I have RT-AC86U
Any thoughts?
UPDATE: My server VPN usernames and PWs have also been lost. Seems like the router is have problems accessing the tables where that information is stored....
Rob
it has been changed for compatibility to include Aimesh in 384.13, set it all again.
Check under Tools -> Sysinfo, make sure you are not running out of nvram.
I have RT-AC86U
Any thoughts?
Rob
I had the same issue - problem was I had no free NVRAM due to a corruption - check on Tools - sysinfo page. To fix, I had to factory reset and manually re-enter all settings - don't restore as that will bring back the corrupted nvram again
