abedinthehouse
This is my first post and I have been doing a lot of research and narrowed it down to the DIR-855, DIR-825, Netgear WNDR3700
If I install the latest firmware on the DIR-825 or the DIR-855, can I browse the contents of a USB hard drive connected to the router on my Xbox 360 and play them?
Also is it possible to connect a USB HUB to the router and attach multiple hard drives and a printer to the hub and successfully access them all on a computer or Xbox 360?
And has Netgear provided any firmware upgrade that lets you connect a USB hub or printer to their WNDR3700?
Lastly, which would you guys all recommend? Ive read all the reviews on maybe over 20 routers, I need a dual band dual radio gigbit port router with USB (preferably for HDD and printer sharing over a HUB)
Thank you
Thank you
