SysXpl
Hi! First post here, so far (last several years) I have been just reading guides and information on this place. Which has been great, when needed.
I got an Asus RT-AX88U Pro with up-to date Merlin. I got a new printer that I want to avoid replacing. It's an Canon TS5151, without ethernet and it seems like it does not either have support for WPA3 that I use. I have an active (dedicated headless Linux) PLEX server, I appreciate to use the backup feature, if my main connection goes down. So, I and other users still have access to PLEX from outside network. At the same time, I want to make the printer accessable for users within the network (not using guest network) without installing drivers. If I have a visitor, and they have a phone I just want them to be able to print whatever they like without bothering using my computer or installing drivers. I have done any extensive research yet, so don't be too hard on me if missed out something. If it's impossible, or But my spontanius idea, was to use an USB-hub, so I can use the USB-port for both wi-fi dongle and printer server.
I found this thread that points to that I can break the router with a USB-hub: https://www.snbforums.com/threads/r...-hub-to-connect-multiple-external-hdds.73398/
The question is if it's because of an actual USB-hub or it's because in such circumstance, it puts too much pressure on the router? A printserver and backup wi-fi use far less bandwidth than some substitute NAS-solution.
And if I get it working, if it it could really work, I might want to take it a step further with improved security. I have been considering something like "Canon encrypted secure print", but then I have to choose between convinience and security. I have no past experience with printservers, I don't know what is possible to do with Asus printserver or not.
Could I possibly connect USB to the linux server and configure something there? I have also been looking into Wireless adapters with USB input but those seems to use outdated tech, not compatible with WPA3.
