Disable 802.11a,b or 802.a,b,g
PAPPL
since i'm using only 802.11n devices, i'd like to enable only 802.11n on RT-N66u.
Maybe leave 802.11g enabled optional for guests.
Is there a way to permanently disable 802.11a&b or 802.11a,b,g?
Thanks, Pappl
thanks AnthonyArmato.
So there i can set N-only, but i can't see any way to enable g/n only, even a guest-network uses the same setting as main-wireless.
The other settings Legacy and b/g-protection aren't documented in my manual.
Any way to telnet 802.11a&b permanently away?
Thanks Pappl
