Disable Alexa
ApexRon
RT-AX86U Pro running 3006.102.5
In running a protocol discovery app on my Mac I found that Alexa_TCP is coming from my AX86U. My home network is predominately an Apple Ecosystem and I do not want Alexa on it. Is there a way I can disable Alexa?
Yeah, sorry. Brain fade.
It's part of mdns. There's no menu option to shut it down so you'd have to run the following to temporarily disable it (along with the rest of mDNS):
service stop_mdns
service stop_mdns
Thank you.
Also check the Amazon Alexa page on the RT-AX86U Pro to see if it was enabled previously.
Check the Administration > Policy page to see if anything there mentions Alexa. If it does click the Withdraw button (if any) on the one mentioning Alexa.
Make sure to disable the Administration > System > Remote Access Config > Enable Web Access from WAN option.
And disable WAN > DDNS, if not using DDNS.
All settings were as you stated. Still shows Alexa TCP
