Disable avahi daemon on Asus RT-AC68U (as it is consuming 50% CPU)
Avahi Hater
Greetings all
Recently we've bought the brand new Asus RT-AC68U for the our small office.
During the last week I noticed that CPU load for the core #1 is always 100% (screenshot).
I logged in via ssh and run the "top" command. It is constantly showing avahi-daemon on top, eating up 50% of CPU:
  PID  PPID USER     STAT   VSZ %MEM CPU %CPU COMMAND
 1180     1 admin    R    22348  8.7   0 49.5 avahi-daemon: running [RT-AC68U-DC98.local]
And I find it quite irritating.
From what I learned, it's some feature that is absolutely of no use for me.
There is an old post saying "there is no harm in leaving it running". Well, now it does considerable harm and want to turn it off completely. How to do that?
Firmware Version:3.0.0.4.380_7378
Please let me know if you need any other information.
Greetings all
https://www.snbforums.com/threads/what-is-the-avahi-daemon-for.37760/#post-310909
Try the script provided there to kill avahi and bind it to a non-executable path
You'll need to enable jffs scripting in the UI
Thank you.
I just realized that I am likely posting in the wrong section.
I am using the vanilla firmware whereas this sub-forum is related to a customized one. It's hard to sort these things out at first, so I got confused.
Anyway, I suppose it's the reason why I cannot find such an option in my interface, nothing that mention jffs at all.
Edit: At first I posted it into Merlin sub-forum and now it has been moved by mods to the proper section.
Greetings all
What is your local domain? Make sure it's not something *.local, as this extension is reserved. Avahi should normally not consume any CPU.
Exactly... avahi is very lightweight normally.
Quick tip - Windows Server, if not bound to a top level domain, defaults to .local - and yes, this can cause problems..
MS has a tech note on that item... can't find it at the moment.
Thank you.
Actually, recently I set up not a server but just an ordinary Linux workstation within the same local network, which TLD indeed was .local.
So I just made it something different and will check avahi-daemoin after rebooting the router.
Thank you.
Using .lan is a good choice for an arbitrary TLD...
