Disable DHCP for native IPV6?
Jumpstarter
So my goal is to only hand out one address via ipv6, and disable DHCPv6 assignment for the rest of the network. Is this possible via custom script options or from a GUI option? Can someone sorta guide me on the right path here or suggest script knowledge?
Get thee to https://ipv6.he.net/certification/ and begin with incorporating the knowledge. (It's free and might take an hour of your life)
You really only need the 1st and 2nd "levels" ...so you can become a SLAAC-er. ;-D
I am really just looking to be able to manually assign ipv6 addresses to clients with dhcp advertisement turned off. Similar to assigning ipv4 addresses manually to devices. Can some one advise me on this matter?
