Discover IoT device from HASS on Main LAN to Guest Network
mr_planet
Hello all,
I have some problems with Home Assistant integrations and devices, seeking for help.
In the specific, I’m trying to get a TP-Link Tapo smart plug discovered by Home Assistant using the “TP-Link Smart Home” integration (goes via local network), but discovery doesn’t find it.
Some details about my setup:
  • Home Assistant is on the main LAN, wired, with mode: All (default).
  • Tapo smart plug is on the Guest Network, without access to the intranet.
  • I have an Asus RT-AX86U Pro with latest Merlin firmware. YazFi is not supported.
  • I haven’t added any custom firewall rules yet, just the default guest/IoT isolation.
Because IoT is on the guest network and HA is on the main LAN, the discovery and direct access is blocked between the two.
What’s the recommended way to make discovery and control work in this scenario, while still keeping the IoT/guest network isolated from the main LAN as much as possible? Do I need specific routing or firewall rules (e.g., one‑way from HA → IoT), and if so, what would that look like on Asus Merlin?
Unfortunately I can't install YazFi via AMTM because doesn't support latest firmware and I am reluctant to make routing changes directly from ssh; I would prefer something directly in the UI or that assists me in making these changes.
I was able to overcome this problem with the cloud integrations, but TP-Link doesn't provide it and, honestly, would be really nice to move out from the cloud based integrations to actually direct access.
Thanks in advance!
Just to clarify, are you running the old version of Guest Network, or are you running Guest Network Pro under the 3.0.0.6.x branch of firmware?
Please use the forum search feature if you haven't done so already. There are numerous past discussions on the problems with Home Assistant on the main LAN not being able to access devices on Guest Networks/Guest Network Pro profiles (Asus-Merlin 3006.102.x firmware) and various methods including custom firewall-start / IPTables scripting (some successful some not) that people have used to try and solve the issue. For example:
