Trankonia
Has anyone seen these issues with AICloud? 1. The devices showing up when you connect into the domain are listed on top of each other (on the same display line, rather than as expected. 2. It is also listing an internal system that I do not want to expose to the WAN. I only want the devices that are plugged into the router's USB ports to be accessible. The router tis the Asus AXE7800. It has 2 drives connected to the USB port using a powered USB switch. I have tried 3 different Browsers and all of them display like the image below.
