Diversion causing DCD Tainted
clvk07
Running 386.1 Beta on AX86U, only Entware , Diversion and Skynet Installed.
If Diversion is enabled I get a lot of DCD tainted errors. Did some testing, disabled Skynet, still errors, enabled Skynet and Disabled Diversion, errors gone. Running DIversion with pixelsrv enabled.
I used to have a similar setup with AC86U, (384.19) and was getting same errors. At the time I thought was Asus/Trend issue, but noticed a Merlin thread where he says issue has been fixed but still users reporting on his firmware which might be do to with scripts... I can definitely confirm that diversion is the issue for me.
@lonelycoder , are you aware of the issue, do you need any other log?
known issue, trend micro / asus issue. dcd crashes if you set up an alias interface as pixelserv does
not sure who is the developer mention in Merlin post in another thread, could it be because the length of the alias br0 pixelserv-t ? would something like br0 pix be worth to try?
"At the time, another developer came up with the theory that what was triggering the issue was configurations that had either many additional network interfaces, or had interfaces using longer names, causing buffer overruns within dcd. I don't know if it ever got confirmed or if it was just a theory."
