Diversion Diversion crashes every few days
Wouldn't it be easy to replace the single quotes with double quotes when enclosing the string assigned to the adsCountLM variable?
If there's any chance that the string could also contain double-quotes, it's easy to escape those.
For example:
Or, is there some specific technical reason that the code must use single quotes to assign the variable?
I haven't looked closer at the rest of the code, so perhaps there's a reason for it.
Just my 2 cents.
Storing a variable that contains special chars is always a challenge - especially if you want to grep that exact string later on. Using a single quote for the Dnsmasq line worked for years now. I am unwilling to change it.
I wish any important input field would strip special characters like these. It's such a bad practice to allow these. Or nulls. Found that out the hard way when people were naming their USB drives a null value, which subsequently became a required field name in AMTM when formatting a new drive.
Exactly my point. Next thing users want is blancs in domain and email names.
Some things are simply not meant to be or cannot be done.
Ah, I understand. It's a case of "risk vs. reward" trade-off. You're afraid that fixing one thing might break something else, especially when the fix addresses a small use case (e.g., using apostrophes) that does not follow the standard naming conventions that are considered good industry practice; hence, the unwillingness to take the risk for little benefit.
I'm testing this with my main and test routers, looks like it has no negative affect so far even when a single quote is used in the dnsmasq.log 👍
Let me run it that way for a few days here before I release an update.
