DNS Filtering & Avast Antivirus
mattbooty
Using the DNS Filtering on the router and setting it to OpenDNS works for MOST things, but Avast virus updates are failing. If I turn it off on the router and set the DNS on the PC to be openDNS servers, the updates work fine, so I'm pretty confident it isn't opendns or avast at fault.
Any thoughts? I could turn it off on the router and set up DHCP to hand out the opendns servers, but i like the idea that i can granularly change what devices have what filtering (or no filtering).
Thanks!
On Firmware 380.66_4
Maybe Avast is using some anti DNS hijacking technology to prevent what DNSFilter does - redirecting to a select DNS. If that's the case, then unless there's a way to disable that in Avast, I doubt there's anything that could be done about it.
