gamewarden3006
RTN66U Firmware 3.0.0.4.220
ok this is probably simple but I do have a question about the DNS settings on this router.
I am on DSL, under the WAN tab on left I have checked no to connect to DNS servers automatically and I have entered the 2 server I wish to use. Simple enough.
what is confusing me though is that there is another place to put DNS into under the LAN tab on left then under the DHCP tab on top. there is a place for DNS / WINS. it says if you leave it blank then the router does the DNS...
so am I correct in thinking that if I leave the one under LAN blank that the router will simply pass route the DNS request to one of the 2 servers I specified under the WAN tab?
If not, what am I missing?
Thanks for any help
Thanks for any help
