DNS timeout weirdness
Saus
Hi guys,
Please help me with this weirdness I suffer with DNS timeouts. Background:
- recently migrated from RT-AC86 to AXE-16000
- using AMTM/Diversion, large list
This happens:
rvds@RoutingBakkie:/tmp/home/root# nslookup brazzers.com
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 66.254.114.234 reflectededge.reflected.net
rvds@RoutingBakkie:/tmp/home/root# nslookup asus.com
Server: 127.0.0.1
nslookup: can't resolve 'asus.com'
Server: 127.0.0.1
rvds@RoutingBakkie:/tmp/home/root# nslookup geeksforgeeks.com
Server: 127.0.0.1
Address 1: 199.59.243.222
Server: 127.0.0.1
Address 1: 103.10.4.216 asus.xn--fiq66s
In other words, seems quite random, a domain (repeatedly) can't get resolved, while others can, and after a little while, that one can again, too.
I have tried switching from ISP DNS to others, such as Google, OPENDns etc. and currently running with 8 servers and --all-servers in dnsmasq.conf -- so the upstream servers cannot be the problem I would think.
Also log-async, so DNSMasq should not be choking.
Mem, is huge, have a 10gb swap on usb in addition.
Proc power on this quadcore unit... should not be it either.
Otherwise I don't think I have done anything special in terms of configs.
Also I tested the above straigth on the router via SSH to avoid any client issues.
Whelp! :)
bbunge
Part of the Furniture
Your 10 GB swap is too big! Rule of thumb is a swap less than or equal to the system RAM. But that is not the problem.
Eight upstream resolvers? Why? Use two in the WAN DNS settings then two DoT but four if you use IPV6.
And Diversion is not slowing things down....
Saus
Thanks very much. Ok noted re swap.
Please note that I added the 8 upstreams only after the problems occurred, to test whether that would mitigate. So not the root cause (tried it without to verify).
Not Diversion (why are you sure?) -- what then?
L&LD
A swap file is either used or not. There is no such thing as swap being 'too big'.
ColinTaylor
This is incorrect. Applications may adjust their memory usage based on how much virtual memory is available. Having too high a ratio of virtual to real memory encourages the occurrence of thrashing, potentially causing the router to "grind to a halt". The slower the backing storage is the worse the problem becomes. It is therefore important that swap space is sized appropriately for the given environment taking into account the speed of the backing store (e.g. fast SSD vs slow USB flash drive).
dave14305
Follow the unfiltered dnsmasq log in diversion and see what gets logged when you make the query in another session.
L&LD
What you've stated is correct, in its own context. However, what does that have to do with the OP? Nowhere is it indicated that the swap file is the issue here.
ColinTaylor
It has nothing to do with the OP's problem and neither did your post. I was just correcting your statement that "A swap file is either used or not. There is no such thing as swap being 'too big'." which might mislead other readers.
L&LD
You don't need to correct my post. I know how I wrote it. It was in response to the posts above mine.
If a swap file can be too big, that is an OS issue and not the size of the swap file.
Saus
For those quibbling about that: I adjusted the swap to the size of my real mem. So that’s out of the way.
I will look at the log in the way suggested and revert, thanks all!
B255ea006
Hi @ColinTaylor
What does that mean?
And how do i calculate the correct size of an SWAP file?
I do have an ASUS RT-AX86S with 1,8 GHz dual-core processor, 256MB Flash and 512MB RAM.
Are 10 GB for a SWAP file OK?
My SanDisk Ultra Fit 32 GB USB 3.1 Flash-Drive with max. 130 MB/s read speed.
Crimliar
Umm, depending on how the router is set up isn't what the OP is seeing from nslookup what happens when a domain name is blocked by diversion?
Saus
For the experts, to answer definitively, but I do not think so. Firstly, eventually the domain, does get resolved. Secondly, looking at the dnsmasq log follow, it clearly states when something is blocked.
