dnsmasq and pxe
Mobo1964
I'm trying to get pxe working on my RT-AC66U.
I placed dhcp-boot=pxelinux.0,,192.168.0.1 in /jffs/configs/dnsmasq.conf.add and even in /jffs/configs/dnsmasq.postconf but both are not working.
Also tried when copying dnsmasq.conf to /jffs/scripts and add the dhcp-boot option to it.
When I check nvram show | grep pxelinux or nvram show | grep dhcp-boot there is nothing.
Anyone?:confused:
Did you either reboot the router or restart the dnsmasq service after doing these changes?
There's no reason for any of these strings to ever appear in nvram.
I did a reboot several times.
At this moment I have a copy of dnsmasq.conf located /jffs/configs with the dhcp-boot=pxelinux.0,,192.168.0.1 added.
Is there a method to see of these settings are added to dnsmasq?
There is another strange thing I discoverd.
At /jffs/scripts I have wan-start
-rwxrwxrwx 1 admin root 295 Nov 30 18:38 wan-start*
this should also start after a reboot and sent an gmail notification, and other things. This is also not starting.
admin@RT-AC66U:/jffs/scripts# cat wan-start
#!/bin/bash
sh gmail-notification
date >/tmp/wan-start.txt
sh vpn-reroute
echo "" >>/tmp/wan-start.txt
echo "VPN Reroute script running" >>/tmp/wan-start.txt
echo "Mail startup script running" >>/tmp/wan-start.txt
Gmail-Notification
admin@RT-AC66U:/jffs/scripts# cat gmail-notification
#!/bin/sh
FROM="xxx@gmail.com"
AUTH="xxx@gmail.com"
PASS="xxx"
FROMNAME="Asus RT-AC66U mijn Router"
TO="xxx@gmail.com"
ntpclient -h pool.ntp.org -s &> /dev/null
sleep 5
echo "Subject: WAN state notification" >/tmp/mail.txt
echo "From: \"$FROMNAME\"<$FROM>" >>/tmp/mail.txt
echo "Date: `date -R`" >>/tmp/mail.txt
echo "" >>/tmp/mail.txt
echo "I just got connected to the internet." >>/tmp/mail.txt
echo "My WAN IP is: `nvram get wan0_ipaddr`" >>/tmp/mail.txt
echo "Uptime is: `uptime | cut -d ',' -f1 | sed 's/^.\{12\}//g'`" >>/tmp/mail.txt
echo "---- " >>/tmp/mail.txt
cat /tmp/wan-start.txt >>/tmp/mail.txt
echo "Your friendly router." >>/tmp/mail.txt
cat /tmp/mail.txt | sendmail -H"exec openssl s_client -quiet \
-CAfile /jffs/configs/Equifax_Secure_Certificate_Authority.pem \
-connect smtp.gmail.com:587 -tls1 -starttls smtp" \
-f"$FROM" \
-au"$AUTH" -ap"$PASS" $TO
rm /tmp/mail.txt
rm /tmp/wan-start.txt
Just see if /etc/dnsmasq.conf contains it.
#!/bin/bash
There's no Bash in the firmware. You must use #!/bin/sh as the shebang.
#!/bin/sh was the solution, Now pxe is also running.
Thanks for the support
