dnsmasq.postconf not running
RichS
I've been trying to figure out why my dnsmasq.postconf script isn't running when the router boots up. I'm currently running an Asus RT-AC68u with Asuswrt-Merlin 384.10_2.
Afaik, the permissions are correct:
admin@crouter:/tmp/home/root# ls -l /jffs/scripts/dnsmasq.postconf
-rwxr-xr-x 1 admin root 130 Apr 20 02:08 /jffs/scripts/dnsmasq.postconf
I've tried adding some logger calls, but they don't show up in syslog. Here's the current source:
admin@crouter:/jffs/scripts# cat dnsmasq.postconf
#!/bin/sh
CONFIG=$1
logger dnsmasq.postconf
for script in $(/opt/bin/find /jffs/scripts/dnsmasq-postconf.d/ -type f); do
logger Run $script
source $script $CONFIG
done
The strangest thing is that the script IS executing when I do a service restart_dnsmasq, just not when the router boots. Any hints or debugging tips would be greatly appreciated.
#!/bin/sh
CONFIG=$1
logger Run $script
done
Is Entware loaded before dnsmasq starts? Maybe /opt/bin/find isn’t available to use yet.
That was it! Thank you for the tip.
I opted for GNU find because the Busybox version doesn't support -type and shell globbing wouldn't work correctly if nothing was matched. Final solution:
for script in /jffs/scripts/dnsmasq-postconf.d/*; do
if [ -f $script ]; then
fi
done
