Download Master Tasks not showing up
clvk07
Running latest 380.59 and it seems that the torrents are not visible anymore from the task page. They run on the background. It was working fine up to few days ago. I uninstalled the client, deleted asusware directory, reinstalled, no joy. Any ideas?
I don't know about download master - i left that one in the dust after i found out that i could install Transmission.
I also had problem with the UI not updating in download master (on removing torrents etc.).
You might wan't to give transmission a go: there is a good install guide here (if you have an ARM router): https://www.hqt.ro/transmission-on-asuswrt-routers-through-entware/
You do need to have your drive formatted in Ext2, Ext3 or Ext4 format though (or run transmission/Entware on a separate USB-disk in Ext2, Ext3 or Ext4 format).
I can also recommend this extension for Chrome: transmission-easy-client - is makes it super easy to add torrents right from the right click menu in Chrome.
