DownloadMaster freezing
Cetar
Hi guys.
Firstly i want to say that work on Merlin is great and i really appreciate it. But i have a big problem. I am running 374.40_beta1 Merlin, but this problem is with asuswrt too - it is the reason why i tryed merlin. Well, i have brand new formatted USB 3.0 my passport(same problem with usb 2.0 my passport) hdd mounted with Downloadmaster ver. 3.1.0.85 installed on it. When i download small torrent files - cca 1GB, i have no problem, but i tryed to download 13 GB file with biggest file 4.34 GB. Both hdd were NTFS. It was downloading about 10min, or allocating space, i dont know and after that it completly freezed. WEB GUI isnt responding, ftp works but only to root hdd, not in directory. Lan and wifi works just fine. the only things that arent working are web services. I cant reboot the router manualy because i am away from home, but thank god for merlin SSH (love u for that :). I tryed reboot with ssh, but reboot command isnt working, and in about 5 min freezes ssh connection with putty too. So i tryed other commands. I tryed "shutdown -r now" and "reboot -f" nothing worked immediatelly but in a few sec it worked and rebooted router. Have you got anny suggestion for downloading bigger files because it is the purpose of this - not to have pc running in night but download bigger files all the time. Thank you for help.
Martin
Filesystem
May i ask which filesystem do you use for usb hdd? I use ntfs and i have that problem.
