Downloadmaster not showing in download files, how to reset settings?
Fire-Dragon-DoL
I did something stupid (I was doing some tests), I copy pasted the content of a torrent inside the textarea for magnet links to see if "it was smart enough" (I'm trying to create some command line tool). From that point on, download master STOPPED showing the files in task area (both in download/finished), even if it's downloading (I can see bytes increasing on the HDD).
My main idea was disable, uninstall, umount the hdd, connected to linux, deleted everything inside "asusware" and in "Download2" (have a backup copy), Rebooted router (hard, through button).
Reinstalled Download Master and applied the updated, first thing I noticed is that IT HAS OLD SETTINGS... So, where are saved those settings?! I thought I had deleted those.
Are there any way to reset "cache" of download master (and settings too) and everything about it?
I really would like to keep using it, it's quite useful (expecially because I use 2 o.s. and I have downloads only on one, but I work mostly on linux).
